PaintSquare.com
Follow us on Twitter Follow us on LinkedIn Like us on Facebook Follow us on Instagram Visit the TPC Store
Search the site
Sauereisen, Inc.
SewerGard® 210XHB
• 300 mils in a single coat by plural component equipment
• Fast Setting
• 100% Solids Epoxy
• Chemical-resistant barrier for municipal wastewater environments
sauereisen.com
DeFelsko Corporation
PosiTector SST Soluble Salt Tester
Measures the concentration of soluble salts on metal surfaces. Use with all Bresle patch types including the reusable, adhesive-free PosiPatch.
Mitsubishi Gas Chemical America
Performance Amine 1,3-BAC
A highly reactive cycloaliphatic diamine offering superior performance. Reasonable cost and curing efficacy makes it suitable for all types of epoxy resin applications.
Carboline Company
New product: Carbozinc® 608 HB
Introducing a new high build zinc-rich primer that can save you time and money by eliminating the epoxy intermediate coat!
CHLOR*RID International Inc.
SOLUTIONS THAT WORK
Companies that invest in corrosion control use CHLOR RID products
  • Soluble salt removal liquid
  • Test kits to verify contamination levels
  • Surface passivation to hold the blast
INFO@CHLOR-RID.COM 800.422.3217
SABRE Autonomous Solutions
Repeatability
The ALPHA1 provides reliable results consistently allowing you to cost your next job with confidence.
Modern Safety Techniques
With our unique LTCat, we can help to provide clean, safe breathing air to your workers. Take a look at our Breathing Air Systems, we supply at least twice as much charcoal as our competitors! Modern
Bullard
Upgrade with the Bullard GenVX
Click here for your blast helmet.
Fischer Technology Inc.
DUALSCOPE®FMP100 with DataCenter IP
Transfer customized inspection plans from PC to FMP100 using step-by-step guidance with prompts and pictures throughout the measurement procedure
Jotun Paints Inc.
Jotun Jotachar 1709
Mesh-free passive fire protection epoxy designed to protect against hydrocarbon pool fire scenarios for up to four hours as defined in the ANSI/UL1709 standard.
Technology Publishing Co., 1501 Reedsdale Street, Suite 2008, Pittsburgh, PA 15233
TEL 1-412-431-8300  • FAX  1-412-431-5428  •  EMAIL webmaster@paintsquare.com
The Technology Publishing Network
Durability + Design PaintSquare the Journal of Protective Coatings & Linings Paint BidTracker
EXPLORE:      JPCL   |   PaintSquare News   |   Interact   |   Buying Guides   |   Webinars   |   Resources   |   Classifieds
REGISTER AND SUBSCRIBE:      Free PaintSquare Registration   |   Subscribe to JPCL   |   Subscribe to PaintSquare News
MORE:      About PaintSquare.com   |   Privacy policy   |   Terms & conditions   |   Site Map   |   Search   |   Contact Us
